SOLVED printing problem
I cannot print emails. With email on the screen I click on three dots at top right of screen. From the drop down I click on "print". The window which appears shows the email with next to it the text from top "printer", number of copies Tec Unfortunately the window does not go low enough to show the "print" button. Either the window iris too magnified or too high on the screen.
Have you tried resizing the print window.
Generally you can hover your mouse over the top, bottom or corner of the window until it turns into a double ended arrow and the left click and drag to resize it slightly, which may be enough.
Other wise it may come down to your screen resolution
Glad it worked.
Thanks for posting back and letting us know.
Much appreciated.
