Power Options Surface Pro3
I m using a surface pro 3 with windows 10 pro installed.
I modified the registry so i have more power options but after i lost the sleep.
Is there any way to keep both?
I tried also to find the hibernate option that doesn't have it. Whatever i tried it didn't work.
Do you have any idea? If i install an other windows 10 it gonna change anything or its firmware related?
Thank you in advance.
