As described above, I upgraded my Laptop (Asus F550C, everything as I bought it with regards to the specs) to Windows 10. All worked fine for a week, and then while busy on the computer, everything freezes, I do a hard reboot as nothing responds. Then computer doesn't reboot. and get a message along the lines of "Diagnosing your PC's problems". After a while I get this:
After a night of this, and a few reboots later as well as this message:
I eventually get to one of these screens:
Now I downloaded the Windows 10 Media tool in the hope of creating a bootable USB drive to select at Use a Device.
When this works, it eventually gives me the following options:
If I select upgrade, I get this:
If I select Custom, I eventually this:
(though I don't know the product key because I upgraded) and then this:
I don't know where to install to, as I was only aware of two partitions.
I also attempted to "Reset this PC". There I get two options. 1. to keep all my personal info and settings, or 2. To wipe everything clean.
If I try to keep everything, this happens:
If I try to reset and wipe, this happens:
Eventually I can get to this:
Now, I have tried the following:
1. System Restore - Once clicked it says: "No restore points have been created on your computer's system drive. To create a restore point, open system protection".
2. System Image Recovery - Tried to have it recover from the USB image, but will only allow it to recover from a DVD.
3. Start-up Repair - Does nothing only cycles back to this blue screen.
4. UEFI Firmware Settings - The only thing I did here was to try and start Windows 10 in Safe Mode with Networking, but it just got stuck in the Reboot/Repair Cycle and does nothing eventually.
5. Go back to the previous build - PC does not pick up a previous build so it does nothing.
The only thing I didn't try here was the Command Prompt as I would have no idea what to do there once I got in.
I have a feeling that I would need to do a clean install, but I don't want to screw the system up even further if I could prevent it.
At this stage, I am willing to loose every bit of personal info on this laptop if I can just get the damn thing to work. (Getting MS Office back will be a bit of an issue, but it is better than not having a functioning PC at all.)
Can anyone please help me and tell me where I might be able to clean install Windows 10 (or 8 or 8.1 for that matter). Please, any help would be greatly appreciated.
