Personalisation problem
Dear sir I'm from India I install Windows 10 built no. 9926 yesterday
There is some bugs but the most problem is I'm not able to add pictures from library in desktop background under personalisation ,not able to change next background time it always stay in 30 minute ,not able to change centre position and not many time it crashes.
So sir I want help from you for how to fix this problem.
Thank you,hope you will help me.
Your best action, for the moment, is to update to a later build, where you might find the problem is solved. Currently Build 10049 is available.
