SOLVED pci simple communications controller
I have noticed in device manager that the pci simple communications controller is not working.
Everything except the rear mike socket on my HP P.C is working fine.
This seems to be the driver do i need it as everything else is fine
PCI\VEN_8086&DEV_2994&SUBSYS_2801103C&REV_02
Generally that is with the chipset driver. Once you installed 10, did you go to HP's website for you model number and download all the necessary 10 drivers.
No i just installed W10 and didn't notice this was missing until yesterday as everything seems to be working.
As everything seems to be working do i really need to worry about it.
Yes.....very important to have the correct OS version of drivers installed for proper operation.
Well i went to the HP site and entered my model details and nothing is listed for my model and serial number.
Actually nothing is listed for W10
There you go...it's not supported for windows 10. As such, it would be advised to go back you your previous OS.
Note: As an alternative, you could find the chipset driver for windows 8/8.1, download it, install it in compatibility mode. Sometimes this will work.
If its not supported in W10 is it important to have it as everything is working fine the only thing that's not is the PC rear mike socket which i don't need as i have a U S B web cam with mike. ;)
Hewlett-Packard HP Compaq dc7700 Small Form Factor
System Serial Number: HUB7381D8D
Asset Tag: HUB7381D8D
Chassis Serial Number: HUB7381D8D
Enclosure Type: Low Profile Desktop
Main Circuit Board b
Board: Hewlett-Packard 0A54h
Bus Clock: 800 megahertz
BIOS: Hewlett-Packard 786E1 v01.10 04/13/2007
Looking into this a bit further i now think this is a folder left over when i did the upgrade from W 7 to W10.
And this folder is no longer used in W10
So i will mark this as solved.
Many thanks. :)
