Pc will not sleep or hibernate
Since updating windows 10 my pc will not sleep or hibernate. Monitor does but machine stays on. Have tried reseting to defaut, checked all setting nothing seems to work.
I had a similar issue lately, and after a few hours searching, I had found something really easy to do.
You open cmd (Admin) or Powershell (Admin), then you type « powerconfig.exe /hibernate on »,and press “Enter”.
You close the command prompt, and it should be working, no need to reboot.
For unknown reason my “hibernate” was switched off after a cumulative update !??? o_O
Keep us informed ! :)
