No sound from speakers after removing headphone jack
I'm using Windows 10, and on my old PC, switching between headphones and speakers was seamless. I'd plug in the headphones to get sound through them, and when I removed them, the sound would come through the speakers.
However, my new PC behaves differently. I found a solution some time ago, but now I can't get the sound to switch to my speakers. I searched for solutions, but they were complicated. Here's what I remember:
Right-click on the speaker icon in the status bar.
Right-click on 'Sound'.
Sometimes, this opens the "playback" screen directly; other times, I have to select the 'playback' tab.
From the playback window, you can see which device is set to 'on'. If the speakers aren't enabled, enable them. This should work, but I had to disable the headphones too. Once, the headphones showed a green telephone symbol. In that case, disabling the speakers didn't help, but enabling them afterwards worked.
