No Sound and voice recorder does not work
I checked device manager which showed no exclamation marks or question marks. Google Chrome voice recorder does not work and the speaker at the bottom right corner shows a normal speaker icon showing that the speaker is working properly.
There is a USB Composite Device showing up in the USB Serial Bus Controller section of the device manager.
Hi Victor43,
have you tried opening Settings > System > Sound and using the "Troubleshoot" function(s)?. :):):)
Or click on "manage sound devices" and disable the ones you don'e use. I've had conflict with certain ones in the past, and disabling them made the devices I was using work again.
I'll give both ideas a try. Thanks. What about if I were to uninstall the sound device from device manager ? Is this a valid option ?
Thanks to both.
Hi Victor,
you can un-install and restart, it will be auto detected when you reboot!. :):):)
