Hi Lem,
Just so I understand correctly, do you mean that you can't access the mapped drive unless you first click on it within File Explorer? For example, you couldn't save a Word file to z: without that step?
I'm guessing that when you set up the mapped drive, the "auto-reconnect" option was checked? Does the network share require any authentication to connect?
