- Feb 16, 2016
I upgraded from windows 7 to 10 a couple of weeks ago.
Since then every time I start up the computer I have no network connection.
If I just press connect in the network settings box I get the message "cannot join this network".
Instead I have to disable, then enable the network adapter to connect to my wifi network.
I cannot connect through the LAN as my computer is not near the router.
I've looked at various fixes, including one from microsoft, but nothing works.
It is not a router problem as all of my other devices work fine.
It's fairly obvious others are having the same or similar problem but I haven't come across a successful solution yet.
Any help appreciated!!
