- Jun 12, 2016
Microsoft has left us in the lurch with color choices. I need to make my accent color a pale pink and that is not a choice. I have tried all of your options including "control color" and I can't get the color I want. Therefore I am looking at workarounds that involve going into the registry and editing the Special Color choice. However, using hex codes listed on the Internet, I am getting inappropriate colors. I want to know what color system my computer is using. Is it RGB or CMYK or something else? It is an Acer Aspire TC-705 model with a Windows 10 64-bit operating system. I need to know how I can get an accurate hex no. for the registry code for Special Color. Please don't refer me to your tutorials, they are most unhelpful. Thank you.
Also, I have experimented with a workaround that allows me to use a custom color created in Paint and choose it as a background color. The trouble is I cannot then choose a Picture under the "Fit" choice to go in front of it. The Paint program saves the Custom Color as a PNG. Is there any way to add that color to the background color choices given us in MSN. They are very limited and don't always work with my picture displays. Thank you.
