- Feb 8, 2015
Need Driver for Western Digital My Passport mobile Drive wdbaaa3200abk. Western Digital says it will not be recognized by Windows 10.
Rev. Michael L. Burns
I thought it was strange also. I have a 500 GB WD My Passport as well. I hadn't used it since installing Windows 10 but needed to grab some documents off of it but the drive isn't recognized. Tried plugging it in and unplugging it several times as well as rebooting. Never recognizes it. However, when I plug it in or unplug it I do here the normal tone that I usually get when plugging or unplugging a USB device.Are you sure???
I have a 500 GB and a 1TB WD My Passport and they both work fine with Windows 10.
What happens when you plug it in?
Have you tried your other WD My Passport on your Windows 10 install? Does it behave the same way?
Have you tried the 320 in another machine recently to confirm that the drive is working properly?
Unsure as to what this means? All drives behave the same on your Windows 10 install or.....Same weird results.
Equally unsure about this?My other external USB drives work fine.
Does the external HDD have the latest firmware installed...? the last firmware for this EXT HDD was Windows release 3.2.5.1 (updated 9/24/2014) which I have the same HDD and it works fine for me. As Trouble stated above it should be showing as he has shown in Device Manager. Oh just a thought... have you installed the SES driver installed. Can. You take a screen capture of Device Manager and uploaded it to this post...?
Go to WD for the drivers and everything on you EXT HDD http://support.wdc.com/product/download.asp?groupid=209&lang=en
I doubt it is the cable because even though it doesn't recognize the drive, it does recognize the drive being plugged in and removed. But I have tried another cable just to verify and still get the same symptoms.It might be the interface (USB) cable. You might try to acquire a replacement.
Or it might be the integrated enclosure crossover electronics, in which case you probably have a perfectly fine drive inside the case but the enclosure electronics have failed.
Michael, did you ever find a solution to this? I have the exact same problem. Computer recognizes a device is plugged in but comes up as Initio Default Controller in connected devices. I was trying to update the firmware and THE FIRST TIME I PLUGGED IT IN, IT RECOGNIZED IT CORRECTLY and the device also came up in the WD Smartware software. Now, it does not come up anywhere, Windows makes the sound that a device has been connected but, Initio Default Controller comes up in Connected Devices and nothing comes up in the WD Smartware program. I believe the wrong default driver is downloading?? Did you come up with a solution??
Thank you,
Jason
I have many WD Passport drives. When I plug 2.0 drives with 2.0 cables on my USB 3.0 port, I have exactly the same behavior. I hear the sound, but Windows 10 will not see it. When I use a new cable, 3.0, then my Windows 10 detects it immediately. Make sure you are using a new cable 3.0. FYI- I upgrade my Windows 7 to Windnows 10. When I had Windows 7 on same machine it did not happen. It happens now after the upgrade. Hope this helps some of you.Jason,
I never got it working,
Michael
