My wifi adapter keeps moving to usb control
I got a 8811cu wifi adapter but it keeps disconnecting and then I get the error code 43 when ever I try to reconnect it and it says unrecognisable device
It sounds as though you may not have the right driver installed for that device. With it plugged in, go to Device Manager and uninstall the device and driver, then scan for hardware changes (or reboot).
Then what would the right driver be for this deivice
Foktech Wifi Dongle, AC600 802.11ac Dual Band 5GHz Mini Wireless Network USB Wifi Adapter​
There is one here:
But open the device manager and select the dongle, and ask it to update. Select the choice through the internet.
