SOLVED Move C Drive from hard drive to SSD
I have a Dell Inspiron 3580 that came with a 128GB SSD and a 1 TB Toshiba hard drive.
I just saw in 'Disk Managerment' that Win 10 Pro is installed on the Toshiba hard drive and not on the 128GB SSD.
Question - How can I transfer Windows from the 1 TB drive to the 125 GB SSD with using something free?
Using Win 10 Pro, 21H1, build 19043.410
Thanks for any help!
I would recommend Easus Partition Master and the `Migrate O/S` function or perhaps Macrium Reflect, a bit more busy interface but free versions should do it. Its up to you but as always back it up first and find the system image and learn how to recover if it goes wrong.
