Missing Network adapter help!
Hi I have a big problem here I hve searched everywhere done everything but nothing works so I really need help. I accidently uninstalled my Network adapter because I hade a problem with it (I unibstalled it when the Network adapter didn't work)(the network adapter was in the Show Hidden Devices setting). I have literally done everything I have even hard reseted my computer and updated my Bios and nothing of it worked. I have done every trick I can find on the internet and nothing of it works so please I would really like some help.
Hi Alpharobster,
Windows start menu, search for System Info. :)
Are you saying you no longer have an internet connection on that particular computer..or…?
If it was compatible, or a working adapter, there is no way irt would be in "hidden" devices. Presumably you are looking in the Control panel?
Yes I don't have any internet connection on that Pc now and no I am 100% looking in the device manager
tell us the make and model of your computer then we can search for drivers that you could download and solve the problem!. :)
I will just write down everything because I don’t know which one it is.
OS Name: Microsoft windows 10 pro
Version: 10.0.18363 Build 18363
Other OS Description: Not Available
OS Manufacturer: Microsoft Corporation
System Name: DESKTOP-VOG1TR6
System Manufacturer: System manufacturer
System Model: System Product Name
System Type: x64-based PC
System SKU: SKUE
Processor: AMD Ryzen 5 2600 Six-Core Processor, 3400 Mhz, 6 Core(s), 12 Logical proce....
BIOS Version/Date: American Megatrends Inc, 3003, 2019-12-09
SMBIOS Version: 3,2
Embedded Controller Version: 255.255
BIOS Mode: Legacy
BaseBoard Manufacturer: ASUSTeK COMPUTER INC.
BaseBoard Product: ROG STRIX B450-F GAMING
BaseBoard Version: Rev 1.xx
Platform Role: Desktop
Secure Boot State: Unsopperted
PCR7 Configuration: Binding Not Possible
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
Locale: United States
Hardware Abstraction Layer: Version = ”10.0.18362.752”
User Name: DESKTOP-VOG1TR6\Robin
Time Zone: Pacific Daylight Time
Installed Physical Memory (RAM): 16,0 GB
Total Physical Memory: 15,9 GB
Available Physical Memory: 14,0 GB
Total Virtual Memory: 18,8 GB
Available Virtual Memory: 15,7 GB
Page File Space: 2,88 GB
Page File: C:\pagefile.sys
Kernel DMA Protection: Off
Virtualization-based security: Not Enabled
Device Enceyption Support: Reason for failed automatic device encryption: TPM is not usable, PCR7 Bindi...
Hyper-V - VM Monitor Mode E...: Yes
Hyper-V - Second Level Adres...: Yes
Hyper-V - Virtualization Enable...: No
Hyper-V - Data Execution Prote...: Yes
Go here ROG STRIX B450-F GAMING and click support and then drivers and select OS bit type and then select LAN and download and install it.
While you're in there....update any other driver as needed.
Already done this but it doesn't work. I open the file then extract it then I click AsusSetup and then I click Yes then after that nothing happends not a single difference
Have you tried resetting BIOS if you did any overclocking which may cause a problem?. That is where I would start and work my way forwards!. :)
Also, if you can get a Live copy of a Linux distribution, you can test your computer hardware in Live mode and see if everything works including your network adapter!.
A link for you to view (one of many on YT). :)
You have already said you have tried all the available tricks. Did it include this one:
Right click the Start button. Select the Command Prompt (Admin) from the list,
Type the following command: netcfg -d.
Thiswill reset the network settings and reinstall all the network adapters., reboot your computer. It should scan whilst rebooting, for new hardware, and see if the adapter is there again..
