- Dec 13, 2015
I have a 27" monitor and like to have 2 documents on that monitor at the same time, typically MS Edge and another document. Unfortunately, I am unable to Maximize or Minimize my MS Edge screen by clicking on the icon to the left of the "X" at the top right hand corner of the screen. Clicking on that icon, whether it is a single little square or 2 little squares on top of one other does absolutely nothing to the size of the picture on the screen. Whether it is one or the other, I also cannot put my cursor on the edges to try and drag the picture to a larger or smaller size.
What should I do to fix that problem?
PS: this happens only with MS Edge. I have no problem expanding or reducing the size of other documents.
