Microphone not plugged in
Regedit32 Moderator Joined Mar 4, 2016 Messages 3,609 Reaction score 1,142 Dec 17, 2019 #2 Hi Sue, Something you should check is the Privacy settings: Right-click on Start and select Settings In the Windows Settings frame select Privacy Now on left side select Microphone Now on right side check that the option Allow apps to access your microphone is toggled On
S SueJohnson Joined Apr 18, 2018 Messages 38 Reaction score 4 Dec 19, 2019 #3 Unfortunately that was not the answer. It is toggled ON
Regedit32 Moderator Joined Mar 4, 2016 Messages 3,609 Reaction score 1,142 Dec 19, 2019 #4 When you were on that Settings location did you scroll down and confirm Skype is listed and toggled on?
