SOLVED 'Lost' my system tray
The little triangle that I used to click to see my System Tray has mysteriously disappeared, and I can't figure out how to restore it.
Can anyone give me a hint, please?
Thanks in advance.
  • Right-click on Taskbar
  • Select Taskbar Settings
  • Scroll down main window to Notification Area and click Select which icons appear on the Taskbar
Sample image
  • In the window that opens toggle on then toggle off Always show all icons in the notification area
Sample image
Done!
You're Welcome.
You may need to do that again when you receive Cumulative Updates. Lately, it seems each update resets a few things automatically, meaning you need to set things back to how you prefer yourself after installing the update.
