- Aug 12, 2015
How to show the power button on the login screen?
Yes please
That's the one David - do you know how to fix it?
Many thanks David. Unfortunately I don't have that key name. I did find another one (undockwithoutlogon) which had the value already set to 1. May it will get fixed in SP1 one day...This will require registry editing.
The procedures are not complicated, BUT you must follow the instructions to the letter.
If there is a question/uncertain at any stage, STOP. Post back for clarification. OK ?
Let's start....................
Right click at Start button > select Run > in the Run box, type regedit > click OK.
You are now on Registry editing window.
Left column....................
expand ( click the pointer in front of ) HKEY_LOCAL_MACHINE
expand Software
expand Microsoft
expand Windows
expand Current Version
expand Policies
click at System > right side, locate Shutdownwitho...
right click at Shutdownwitho... > click Modify > under Value Data , change the value from 0 to 1 > click OK ( see screenshot.)
Exit registry editing.
That's it.
Restart and see if the Power icon is back on.
Many thanks David. Unfortunately I don't have that key name. I did find another one (undockwithoutlogon) which had the value already set to 1. It may get fixed in SP1 one day.... Thanks for your help anyway. Cheers.
Hi i have followed the above advice and my setting was already set at (1)
is there any thing else i can do
