SOLVED Limited network after setting up wifi hotspot
I was able to connect to any network I needed to. But then
-I setup a wifi hotspot with the "netsh wlan set hostednetwork ..." command through admin cmd, with ssid and a single session password (non keyPersistent).
-I started it once and stopped it with the "netsh wlan start/stop hostednetwork" command.
After that, the networks I connect to say it is "Limited"! It says "No internet access" on the wifi icon, which appears as a connection with warning sign. I cannot use internet-required apps or services. Other devices can connect to the same wifi and use it as normal, so it is probably not a router problem.
Affected device: Lenovo IdeaPad Yoga 13
