Howdy, and before I get singed for not searching and reviewing posts please know that I have. Over the past couple of months I have tried every PowerShell script / scannow, driver update, reviewed control panel settings, installed and ran MANY antivirus programs, replaced batteries, left batteries out for an evening, tried multiple wireless mouses, and yes... even allowed a full MS software upgrade. Still same outcome.
So what has happened is I hadn't used my personal laptop for a couple of months and decided to break it out to backup my cell. Plug wireless mouse #1 in and boot... no left mouse click at all. Being a hardware and software guy from back to the '70's I took it apart and cleaned the contacts and validated continuity. Functions fine. Oh yes, and this is a Logitech M-RAA93. Try it on another computer... works just fine.
So to continue with troubleshooting tried a Microsoft MSK-1056 with identical results. NOTE: And yes, MANY cold and warm reboots in-between.
On to plan 'C'. A Keyspan RF Remote presentation device. It doesn't work just like the other mouses.
Last ditch (with dread, but need to troubleshoot), a wired mouse. Badabing... no problems other than I can't use that for my presentations.
Conclusion is that M$ pushed some update that has affected how wireless mouses interface with Windows 10. I can draw no other conclusion.
I will be sharing this identical post everywhere I see fit until I (hopefully) find a solution. At that point I will share the finding.
Thank you for assistance in advance, Matt
P.S. All of the aforementioned wireless devices work on other systems.
