Laptop power button and sleep settings
Hi all,
I have a Lenovo W510 laptop with Windows 10 Professional. I see in the power settings that I can configure the power button to put the laptop to sleep when pressed. I have it configured as such but when I press the power button, nothing happens. If I manually put the laptop to sleep via the start menu, it sleeps fine.
Am I missing something obvious?
Hi Annorax,
Welcome to the Forum.
Can you do the following please so we can try and resolve your issue:
  • In your Search/Cortana field type comm
  • In the Search results locate and right-click on Command Prompt then select Run as administrator
  • Click Yes when the User Account Control prompts you
  • In the Administrator: Command Prompt console, type or copy & paste the following:
Code:
powercfg /GetActiveScheme
Press Enter key
Sample image showing result (Note this is one of three possible results)
Please post back what your result was.
For example:
GUID: 381b4222-f694-41f0-9685-ff5bb260df2e (Balanced)​
Did you make the option for both power and battery? Also, you do need to hold the button momentarily - about half to one second
