KMODE Exception not Handled
Hey everyone :) I am having an issue with my custom built PC. I built my PC about 2 weeks ago, it consists of a AMD Ryzen 7 3800x, Gforce 2060 super, MSI b550 gaming pro motherboard, a corsaid 650 Bronze, 32 gb of Corsaid 3200 RGB pro ram, and a corsair case. Whenever I am trying to stream games I am playing on twitch, using twitch's software to stream and even other software like OBS, about 30 minutes into the stream I am getting the BSOD and it is usually giving me the stop code KMODE Exception not handled. I have tried to fix it multiple times, and have tried to update my drivers and everything and nothing has worked. Does anyone have any suggestions?
Download Memtest86+ from this location here. Burn the ISO to a CD and boot the computer from the CD from a cold boot after leaving it off for an hour.
Ideally let it run for at least 7 passes / 6-8 hours (overnight even better). First test system as presently configured with all RAM modules in place, If errors appear before that you can stop that particular test. Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Perform the test on RAM sticks individually as well as all possible combinations. When you find a good one then test it in all slots.
See this Guide to using Memtest 86+
