- Nov 16, 2015
I purchased a new Toshiba laptop C75D-B7340 with AMD processor. Installed with Windows 10 Pre Anniversary Update. After getting it up and going and installed software programs it did an update to version 1607 build 14393.105. After the update I noticed that Microsoft Edge or any short cut on the desktop that were connect thru MS Edge would not launch. I searched for fixes and found this KB3189886. Had to manually update it from the Windows site that had it. After installing it, it showed that it was successful and the new version is 14393.187. Rebooted and after doing all the updating and configuring I tried to launch again with no success. It acts like its going to launch goes to the blue screen with the E then goes back to the desktop. If I Launch a shortcut from the desktop I get a small popup screen that says https://(web address.com) "The Remote Procedure Call Failed". Is there another fix for this or are we now stuck with a non working MS Edge.
Thanks for any help.
