SOLVED IRQL_NOT_LESS_OR_EQUAL ntoskrnl.exe
Hello guys, do you have any clues what is happening by checking the dump?
Ask me anything you need to know about my configuration that will help you understand the problem.
Thanks!
  • 112115-7015-01.zip
hmmm I just got this running stock...
Hello Paul and welcome to the forum.
I can't see anything too scary.
I was just composing this reply when you made your second post.
The bug check shows
BugCheck A, {ffffc001e3605f38, 2, 0, fffff80230ca0dd1}
Probably caused by : memory_corruption
And the STACK TEXT reflects
ffffd001`cd5696e8 fffff802`30d64fe9 : 00000000`0000000a ffffc001`e3605f38 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffd001`cd5696f0 fffff802`30d637c7 : 00000000`00000000 fffff802`313e65ac 00000000`00000001 00000008`e405452b : nt!KiBugCheckDispatch+0x69
ffffd001`cd569830 fffff802`30ca0dd1 : ffffe001`e44c9ac8 fffff802`30cb5175 ffffd001`cc640000 00000000`00000001 : nt!KiPageFault+0x247
ffffd001`cd5699c0 fffff802`30ca0b41 : fffffa80`035a7bc0 00000000`00000000 00000000`00000001 fffffa80`04546a10 : nt!MiDereferenceControlAreaPfn+0x1d
ffffd001`cd569a00 fffff802`30d19e94 : fffffa80`035a7bc0 00000000`00000000 00000000`0011e294 fffff802`30f18ec8 : nt!MiRestoreTransitionPte+0x101
ffffd001`cd569a80 fffff802`30df6f18 : 0000000f`ffffffff 00000000`00000000 00000580`00000000 00000000`00000001 : nt!MiRemoveLowestPriorityStandbyPage+0x184
ffffd001`cd569b10 fffff802`30c82b79 : fffffd80`00003d10 ffffe001`e330c040 fffff802`30df6e8c fffff802`30f19aa8 : nt!MiRebalanceZeroFreeLists+0x8c
ffffd001`cd569b80 fffff802`30c21125 : 7201d8ff`6701e6ff 00000000`00000080 ffffe001`e041e040 ffffe001`e330c040 : nt!ExpWorkerThread+0xe9
ffffd001`cd569c10 fffff802`30d5f606 : ffffd001`cc5d5180 ffffe001`e330c040 fffff802`30c210e4 eeff9b00`e4ff9a00 : nt!PspSystemThreadStartup+0x41
ffffd001`cd569c60 00000000`00000000 : ffffd001`cd56a000 ffffd001`cd564000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
You can see the reference to both PTE (Page Table Entry) and PageFault, so......
I was going to recommend that you check your system drive for errors and then follow up with checking your System Memory with memtest86+
Looks like you've got things under control.
Check and confirm that your memory modules are properly seated.
Check them in alternate slots on the board
Test them one at a time.
sorry to have wasted your time, obviously its a hardware problem and has nothing to do with win10... i'm an idiot :confused:
fixed it by changing slots AND setting the mem to 10-10-10-30 though i'm not sure what the problem is cause the other slots also gave errors @9-9-9... Testing Sticks single channel one at a time seem fine, no errors.
memory or motherboard or CPU slowly dying maybe....
