IRQL_NOT_LESS_OR_EQUAL BSOD
Hey I've been getting a ton of BSOD lately most. Usually happens when I'm gaming.
Here's the latest one
  • 072016-3875-01 - Copy.zip
Nothing looks to scary to me.
BugCheck A, {fffff680bd1a5d38, 2, 0, fffff8027e6b0182}
Probably caused by : memory_corruption ( nt!MiAgeWorkingSet+302 )
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
STACK_TEXT:
ffffd001`cb7a30d8 fffff802`7e7524e9 : 00000000`0000000a fffff680`bd1a5d38 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffd001`cb7a30e0 fffff802`7e750cc7 : ffffe000`155a6000 00000000`00000801 00000000`00001000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffffd001`cb7a3220 fffff802`7e6b0182 : 00000000`0000014e 00000000`00001000 00000000`000001fd 00000000`0000dac7 : nt!KiPageFault+0x247
ffffd001`cb7a33b0 fffff802`7e6bbd9a : ffffe000`14f44580 ffffe000`09a19240 ffffe000`14f44580 0c0d0e0f`00000000 : nt!MiAgeWorkingSet+0x302
ffffd001`cb7a3700 fffff802`7e6bb7eb : fffff802`00000000 ffffd001`cb7a3980 ffffd001`cb7a38b0 00000000`00000000 : nt!MiTrimOrAgeWorkingSet+0x15a
ffffd001`cb7a37b0 fffff802`7e60b9d3 : fffff802`00000000 00000000`00000000 00000000`00000138 00000000`00000002 : nt!MiProcessWorkingSets+0x1fb
ffffd001`cb7a3960 fffff802`7e72b449 : 00000000`00000004 00000000`00000004 00000000`ffffffff 00000000`00000001 : nt!MiWorkingSetManager+0xa7
ffffd001`cb7a3a20 fffff802`7e64ba45 : ffffe000`09bca040 00000000`00000080 fffff802`7e72b2f8 00000000`00000000 : nt!KeBalanceSetManager+0x151
ffffd001`cb7a3b10 fffff802`7e74cae6 : ffffd001`d143a180 ffffe000`09bca040 fffff802`7e64ba04 00000000`00000000 : nt!PspSystemThreadStartup+0x41
ffffd001`cb7a3b60 00000000`00000000 : ffffd001`cb7a4000 ffffd001`cb79d000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
Basically a common run of the mill pagefault, which can be caused by a number of possible sources.
Typically drivers but I don't see anything called out specifically.
I would probably start with Avast and uninstall it using the Programs and features applet in the Control Panel and follow that up with the vendor specific proprietary removal tool from here https://www.avast.com/uninstall-utility
After you clean that up, see if you can make it Blue Screen.
IF the problem persists then I would suggest getting to ASRock and seeing what the have in the way of a BIOS update for that board. Looks like there might be a few newer than the version you are currently running.
