- Jul 29, 2015
Just wanted to inform member about a very interesting thing that happened to me doing a clean install this morning.
L8R,
Nibs
- I had downloaded the 3.10GB 64-Bit Pro ISO file using the "Media Creation Tool" and used Rufus 2.2 to burn it to a USB Flash drive. I had originally used the download to do an "upgrade" install through Windows Logo and that went fine. System seemed a little too pokey for me so I decided to do a clean install.
- The install would start from boot-up and start loading files til about 11-12 percent and then I got that error message stating the file could not be installed. Tried this THREE times and always the same result. I was a little miffed to say the least.
- Then I remembered about the link for the other ISO download via: http://www.microsoft.com/en-us/software-download/techbench
which is a 3.802GB in size ISO file for the 64-Bit Home / Pro version. I burned this to the same USB Flash Drive using Rufus again and the install went without a hitch. The install does give a choice between installing either Pro or Home, you just select the version you need which matched your old version of Windows 7, 8, or 8.1. I skipped the "KEY" part until it was all installed and on the final boot I entered the key everyone gets for a Pro version which ends in "-3V66T". - I then installed all my drivers in the correct order while disconnected from the internet, then connected to the internet and the online activation went through without a single hitch and all is good now.
L8R,
Nibs
