SOLVED IE Favorites not migrated to Edge during installation?
This is more of a statement about my installation than a question...
I just installed Windows 10 over my Windows 7 Pro installation. Everything seemed to go well. I can see most of my stuff migrated (background, start menu items, etc.). BUT one thing that I was sure should migrate didn't - my Internet Explorer Favorites are nowhere to be found in the Windows 10 installation.
It took some digging, but I discovered that IE is still installed in Windows 10. Clicking the ... button gives you the option to "open with Internet Explorer".
To migrate your favorites from IE to Edge, click the ... button in Edge and go to Settings. You will have an option to "Import favorites from another browser" - and IE is one of the "other browsers" available.
Hope this helps someone.
Good tip Calab..... thanks for sharing.
