To update the driver, click the Start button, then Settings, then Devices.  Scroll to the bottom of the screen and click Device Manager.  When there, select 'Audio inputs and outputs', then right click on whatever shows for 'Speakers'.  Select Update driver software from the popup menu, and then when asked how you want to search for the driver, choose the 'Search automatically' option.  Follow the instructions that appear from that point on.   Hope that helps.
