I received #1 - No integrity violations and then ran the second command by accident and it completed successfully as well... Restarted machine and same problem with the Start Up button...
At the same time that I noticed the Startup Button problem, I also noticed that the File Manager icon had a big red X on it... Any attempt at left or right clicking this icon causes it to disappear... Right clicking it will take you to the This PC screen, icon disappears, and left clicking does nothing and causes the icon disappear...
Third problem involves the Action Center icon... Hovering over it, it tells me I have new messages, left clicking it does nothing, right clicking it gives me two prompts, Open Action Center and Turn on quiet hours... Clicking Open Action Center does nothing, but I can turn on the quiet hours...
As I'm typing this I'm thinking that I should check my mouse setting, lol... Will do and if you have any ideas or questions, you know where I'm at!!! Thank You!!!
Give this a try.................................
Right click at Start button > select Command Prompt (Admin) > type powershell > press Enter > wait a bit until you see....
PS C:\windows\system32>
At the flashing prompt, copy and paste this( please use Copy and paste to avoid typo) ............
Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
> press Enter.
Ignore any error in red.
When finished, try Start button again.
> press Enter.
Dave, that worked!!! Start Button and Action Center icon are now working they way they did previously... File Manager icon does not show up anymore which I assume is normal, being that I suppose it only shows up when it has a red X on it... Everything seems Hunky Dory again and I thank you for that fix!!!
Thanks again, and if I need to rate you anywhere, let me know where!!!
I cannot left click my Start Button, only a right click works, but does not give the same results.
> press Enter.
Get-AppxPackage -AllUsers| Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”}
My sister and I had the same issue. I spent hours online looking for ways to fix it and nothing helped. My sister found a way that worked for both of us (her using pc, me using a laptop), Now, I know this isn't the best thing to do for a computer but I couldn't get to certain programs so I gave it a try, even though it sounded idiotic and like it wouldn't work. While it's logged in to a user, pull the plug and cut off power. In other words, hard crash it. If you're using a laptop, unplug it and pull the battery while it's running. Our issues were alittle different, she couldn't left click anything and certain parts of her system were glitching out. For me, I just couldn't use left click for the start menu or anything on the right of the taskbar. But this solution worked for both of us. I'm glad she told me before I backed all my data up and tried to make a new administrative account cause it saved me a ton of time and frustration. Like I said, I know hard crashing a computer/laptop isn't good for it, but it did work. Give it a try if you want, maybe it'll work for you too.
------------------------------Give this a try.................................
> press Enter.
salut, my problem is that in one profile the start button works and the other profile it doesnt. what can i do?I cannot left click my Start Button, only a right click works, but does not give the same results.
