If your flash drive asks to be formatted, avoid formatting it immediately to prevent data loss. You can use BLR Data Recovery Software to retrieve your lost files safely. This BLR hard drive data recovery tool scans your flash drive for lost, deleted, or corrupted files and restores them efficiently. Simply install the software, select your flash drive, run a deep scan, and recover your data with ease. Ensure you save recovered files to another location to avoid overwriting.
Steps to Recover Files from a Flash Drive That Needs to Be Formatted Using BLR Data Recovery Software
If your flash drive asks to be formatted, follow these steps to recover your lost files using BLR Data Recovery Software, a powerful hard drive data recovery tool:- Download & Install – Install BLR Data Recovery Software on your PC.
- Connect the Flash Drive – Insert the affected flash drive into your computer.
- Select the Drive – Launch the software and choose your flash drive from the list of detected storage devices.
- Run a Deep Scan – Initiate a deep scan to locate lost, deleted, or corrupted files.
- Preview and Select Files – Once the scan completes, preview recoverable files and select the ones you need.
- Recover & Save Files – Click the recover button and save your files to a secure location (not the flash drive).
