If your USB flash drive says "Insert a disk into USB drive", it may indicate corruption or hardware issues. First, try some manual fixes: Reinsert the USB into different ports, update USB drivers via Device Manager, or use Disk Management to assign a drive letter. If the drive shows as "USB Drive shown No Media", use the Command Prompt (diskpart > list disk > select disk X > clean > create partition) to reinitialize it. If these methods don’t work, use BLR Pen Drive Data Recovery Software to recover lost data before reformatting. This tool efficiently retrieves deleted, lost, or inaccessible files from corrupted USB drives, ensuring safe data recovery with minimal effort.
Steps to Use BLR Data Recovery Software
- Download & Install: Download BLR Data Recovery Software from the official website and install it on your system.
- Launch the Software: Open the application and connect the storage device (USB, hard drive, SD card) if applicable.
- Select Drive: Choose the affected drive or partition from which you want to recover data.
- Scan the Drive:
- Use Quick Scan for recently deleted files.
- Use Deep Scan for formatted or corrupted drives.
- Preview Recoverable Files: After scanning, preview the recoverable files to verify their integrity.
- Select & Recover: Choose the files you need and click Recover to save them to a safe location.
