It seems like you turned on the crosshair cursor feature by mistake on your computer. This feature is usually for magnifying or focusing on the screen. To get rid of it, just press the Esc key or try Ctrl + Alt + Backspace. That should turn off the crosshairs and get your cursor back to normal.
