I've had Build 18362.1 since 3/20/19, nothing new since. It might depend upon which Ring is involved, I'm on the Fast Ring
In case you have not been keeping up, the fast ring was able to update to 18362.xx without problems. Prior to the slow ring receiving the update, they were given a CU which messed up the 18356.16 folks so they could not update to the assumed RTM. Currently Microsoft is trying to work that out but have set up folks with earlier builds than 18356 to update to 18362 directly if they manually check for updates.
So far I have seen one person which tried that and the update failed at 35%. So, I was just wondering if anyone has been able to update directly to the RTM .. Looks like, so far, not many have tried if they were on an earlier build. Microsoft has not made any official announcements regarding the Spring build release, but this looks like it will be the third build in a row which had problems of some type.
Thanks for the response..
