I am seeking assistance to resolve an ongoing problem with the functioning of the GPU installed in my PC.
History
The desktop PC was built in July 2015 and has never ceased to crash in one way or another when drivers installed since this time I have used the most updated version of DDU software to uninstall drivers on each occasion. Initially, I suspected the problem to be created by windows updates only but later found this not to be the case. Windows updates now manually disabled and blocked.
Technical data
OS: Windows 10 64 bit (Home)
Mobo: ASUS M5A99FX PRO 2.0
CPU: AMD FX 8350 4.0 GHz
RAM: 1866 DDR3 – 32 GB
GPU: NVIDA GrForce GTX 750Ti
Default Search engine: Firefox 68.0 (32 Bit)
Drivers; NVIDIA Geforce GTX 750 Ti (recent as listed below)
Version: 26.21.14.3136 – date 2019-07-03 (431.36) & (416.81)
The following driver appears to have been the best in terms of performance and longevity over the past two weeks
Driver Provider: NVIDIA
Driver Date: 2018-09-05
Driver Version: 24.21.13.9924
Digital Signer: Microsoft Windows Compatibility Provider
History
Technical data
