- Feb 22, 2014
I would post this as a Driver Issue. But I do not believe that to be the case. This issue showed up after an automatic update to 1903. And the connection issue is not every boot. Sometimes I can disable the Ethernet and then re-enable to get it working again. That doesn't always work though. I've even uninstalled the drivers in Device Management then reinstalled them, but that never seems to work. It only takes a few minutes for me to get my network back up and running. Since I rarely reboot and never turn off my machine. I'm only faced with this two or three times a month.
If anyone has a solution I would be grateful to hear it.
I'm still using the same system posted in my profile. MSI P67A-G45 _ i7-2600K _ 8GB DDR3-1866 _ Realtek PCIe GBE Family Controller [RTL8167]
Dropping this link I just found. I'll be checking it out and reporting back.
Realtek PCIe GBE Family Controller - fixed!
Any plans to fix the driver issues with Realtek PCIe GBE Family Controllers? Looks like there are lots of people having issue with the Realtek GBE drivers. Just found the post below and it fix my
answers.microsoft.com
Edit:
The issue within the link was not present on my machine.
