I was these and get exactly this
Deployment Image Servicing and Management tool
Version: 10.0.10240.16384
Image Version: 10.0.10240.16384
[==========================100.0%==========================]
The operation completed successfully.
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
Error: 0x800f081f
The source files could not be found.
Use the "Source" option to specify the location of the files that are required t
o restore the feature. For more information on specifying a source location, see
http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
1.This will take quite some time, but if you care to give it a go.......
Run the followings in the order listed :
1. Dism.exe /online /Cleanup-Image /StartComponentCleanup
2. sfc /scannow (to see if it still finds corrupt files)
3. Dism /Online /Cleanup-Image /RestoreHealth (to double check the image health).
4. sfc /scannow ( optional )
