Hello,
I wondered if someone has any ideas.
I'm trying to do a sysprep but I keep getting the error below.
2018-05-29 15:53:09, Error SYSPRP Package 7EE7776C.LinkedInforWindows_2.1.2639.0_neutral__w1wdnht996qgy was installed for a user, but not provisioned for all users. This package will not function properly in the sysprep image.
2018-05-29 15:53:09, Error SYSPRP Failed to remove apps for the current user: 0x80073cf2.
2018-05-29 15:53:09, Error SYSPRP Exit code of RemoveAllApps thread was 0x3cf2.
2018-05-29 15:53:09, Error SYSPRP ActionPlatform::LaunchModule: Failure occurred while executing 'SysprepGeneralizeValidate' from C:\Windows\System32\AppxSysprep.dll; dwRet = 0x3cf2
2018-05-29 15:53:09, Error SYSPRP SysprepSession::Validate: Error in validating actions from C:\Windows\System32\Sysprep\ActionFiles\Generalize.xml; dwRet = 0x3cf2
2018-05-29 15:53:09, Error SYSPRP RunPlatformActions:Failed while validating Sysprep session actions; dwRet = 0x3cf2
2018-05-29 15:53:09, Error [0x0f0070] SYSPRP RunExternalDlls:An error occurred while running registry sysprep DLLs, halting sysprep execution. dwRet = 0x3cf2
2018-05-29 15:53:09, Error [0x0f00d8] SYSPRP WinMain:Hit failure while pre-validate sysprep generalize internal providers; hr = 0x80073cf2
I've already ran the following command dism.exe /online /Remove-ProvisionedAppxPackage /packagename:7EE7776C.LinkedInforWindows_2.1.2639.0_neutral__w1wdnht996qgy
After running that, I still get the same error. I've also deleted all the built in apps using Get-AppxPackage -allusers | Remove-AppxPackage
I can't seem to get to the bottom of it. Any suggestions would be appreciated.
Thanks.
Thanks.
