Error Code: INET_E_RESOURCE_NOT_FOUND
Hi Tom
Welcome to the Forum.
This is an issue that has affected a number of users since May 2017.
For most users the Windows 10 Fall Creator update resolved the issue, but for others the issue has continued.
Some of those others managed to resolve the issue after notifying their ISP who found a bug in their system that needed addressing.
For other users resetting Microsoft Edge resolve the issues. When you reset Edge, your favorites are safe, but you'll be greeted by the Start page that you may recall seeing the first time you used edge. Closing this, then re-opening Edge gets you back to your usual state.
I've attached a zipped folder that contains a PowerShell script which have been compiled into an executable for resetting Edge browser should you wish to see whether that resolves things for you.
  • Download ResetEdge.zip and right-click on this download and select Extract all
  • Close all instances of Edge that are open
  • Right-click on ResetEdge.exe and select Run as administrator
    • You'll see an elevated command console open, then briefly some text as the script runs.
    • When it stops after about 10 seconds, close the console and open Edge
  • ResetEdge.zip
Since the last update from windows 10 I can not access some websites, I;m getting the message
Error Code: INET_E_RESOURCE_NOT_FOUND and DNS time out. How can I solve this problem?
The error code INET_E_RESOURCE_NOT_FOUND is caused due to windows updates. There are a number of ways by which you can get rid of this error code. Some of them are:
1. Reinstalling Microsoft Edge.
2. Flushing out DNS
3. Many more
A detailed explanation of each method has been given in this article.
How to fix Error INET_E_RESOURCE_NOT_FOUND
It really helped me getting rid of this error code. Hope it helps. Cheers.
2. Flushing out DNS
3. Many more
HELLO,
Issue: How to Fix INET_E_RESOURCE_NOT_FOUND Error on Windows 10?
MY DEAR FRIEND HERE BELOW I GIVE 8 SOLUTIONS FOR THIS ERROR
Solution 1. Disable TCP Fast Open feature on Edge
Solution 2. Reinstall Microsoft Edge
Solution 3. Uninstall Wi-Fi driver in Windows 10
Solution 4. Change the name for Connections folder
Solution 5. Try solving the problem by opening a Private Browsing Session
Solution 6. Flushing DNS might be useful
Solution 7. Change Windows user account settings' options
Solution 8. Reset Netsh
Solution 1.
FIX IT NOW!
To repair a damaged system, you have to purchase the licensed version of Reimage.
Launch Microsoft Edge and type about:flags in the URL address bar;
Press CTRL+SHIFT+D to reveal Diagnostics part;
Scroll down to find Networking section;
Locate TCP Fast Open and uncheck the box;
Disable TPC Fast Open feature to fix INET_E_RESOURCE_NOT_FOUND error
Restart Edge.
FIX IT NOW!
To repair damaged system, you have to purchase the licensed version of Reimage.
Press Windows key + R, type %LocalAppData%\\Packages\\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\\AC\\MicrosoftEdge\\User\\Default, and press Enter;
Right-click on the DataStore folder and select Copy;
Open the Desktop, right-click on an empty space, and select Paste. These steps explain how to create backups of your favorites. Once done, perform the following steps to reinstall Edge;
Close Edge and open File Explorer;
Click View and mark the Hidden items box;
Then navigate to the C:\\Users\\UserName\\AppData\\Local\\Packages directory (Replace “UserName” with your username);
Reinstall Edge to fix INET_E_RESOURCE_NOT_FOUND error
Find Microsoft.MicrosoftEdge_8wekyb3d8bbwe folder and remove it;
Press Yes on the confirmation window to proceed;
Be patient and wait while the process is being executed. If a dialog box opens, click Yes to continue;
If the system refused to delete some of the files, click the Skip button;
Once done, reboot your PC;
After that, press Windows key and type Powershell;
Right-click on the search result and select Run as Administrator;
Navigate to the cd C:\\users\\yourusername (Replace “UserName” with your username);
Copy and paste the Get-AppXPackage -AllUsers -Name Microsoft.MicrosoftEdge | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\\\\AppXManifest.xml” -Verbose} command;
Once done, close Powershell and reboot.
FIX IT NOW!
To repair the damaged system, you have to purchase the licensed version of Reimage.
If INET_E_RESOURCE_NOT_FOUND error occurred on your Windows 10 computer, you could try another method that might help – uninstallation of Wi-Fi driver. Before you start, we want to remind that you should know your Wi-Fi password. Once you uninstall the driver and connect to the Wi-Fi again, you will be asked to enter it.
Access Device Manager by right-clicking the Start button and selecting this option from the list;
Find the Network adapters folder and expand it;
From the list of network adapters, find and yours;
Uninstall Wi-Fi driver to fix INET_E_RESOURCE_NOT_FOUND error
Right-click it and choose Uninstall device from the drop-down menu;
Reboot the computer;
Once you restart the device, Windows 10 should re-install the missing driver automatically.
FIX IT NOW!
If the above-given method were not successful and you still cannot deal with the INET_E_RESOURCE_NOT_FOUND Error on Windows 10, you can give a try to the following solution. Here you will need to access your Windows Registry[6] and change the name for a certain folder. Make sure that all actions are completed as required in the instructing steps. Additionally, this method has been confirmed by the Microsoft company itself and has a big chance of success.
Make sure that you have logged in to your Windows computer as the Administrator.
To open Windows Registry, press the Windows key and R button on your keyboard.
Once a run box shows up, type in regedit.
After that, click OK.
Locate the HKEY_LOCAL_MACHINE folder and expand it this way: Software > Microsoft > Windows > CurrentVersion > Internet Settings > Connections. Fix INET_E_RESOURCE_NOT_FOUND Error on Windows 10 by changing the name for Connections folder
Furthermore, right-click on the Connections folder and rename it by adding some type of letter or number, for example, Connections1.
To save your changes, press Enter.
FIX IT NOW!
Note that this fixing method is a temporary one if there is a crucial need to access a certain type of webpage. If you are in an urge to enter a website, perform the below-given steps.
Open your Microsoft Edge web browser application.
Find the three dots that are located in the upper right corner of your browser.
Select the function that says: New InPrivate window.Open a Private Browsing Session via Edge to fix INET_E_RESOURCE_NOT_FOUND Error on Windows 10?
FIX IT NOW!
Locate your Windows search bar and type in cmd.
Once Command Prompt appears, select it.
Run cmd as Administrator.Use cmd as admin to fix INET_E_RESOURCE_NOT_FOUND Error on Windows 10?
After that, type this command in the black dialog box: ipconfig /flushdns.
Continuously, hit the Enter key.
The process should have been successful.
FIX IT NOW!
Open the run box by pressing the Windows key and the R button together at once.
Type in control and hit OK.
Click the Users Accounts option, and when it appears in the other window, click on it again.
Click OK and Save to save your changes, and Yes to confirm.
FIX IT NOW!
We recommend users trying this option only if the other variants did not work. By confirming this method, all settings might be renewed and refreshed, so follow the below-written steps carefully.
Go to your Windows search zone and find Powershell.
Make sure that you choose Windows Powershell (admin).Fix INET_E_RESOURCE_NOT_FOUND Error on Windows 10 by running commands with Powershell
After that, press Yes.
Type in this command: ipconfig /all > C:\\ipconfiguration.txt in your Windows Powershell to make sure that your IP's configuration is kept safe.
After that, paste this command and hit Enter: netsh int ip reset c:\\resetlog.txt.
Then, type in this: netsh winsock reset. Hit Enter again.
Reboot the machine.
Then you should connect to Wi-Fi network, enter your password and check if the error is gone. However, if none of these three methods had worked, you can undo the latest update. You can find instructions here.
