SOLVED Erasing screenshot problem
In Windows 10, when I switch on my PC a screenshot appears which I want to erase (this appears before PC security password is entered) The shot was taken on the PC camera...but I can't find it anywhere else on the PC in order to erase it...it only seems to exist in that initial startup. Any ideas? Mike M
Hello and welcome to the forum
Sounds like the first screen you see at startup which is part of the Windows 10 "Welcome" process.
Check
Settings -> Personalization -> Lock screen
You can use either "Windows spotlight" a Static Picture or a Slideshow
Experiment with those choices and see if it changes what you see at startup
