Enlarge Fonts
how can i enlarge the size of the font beneath the icons on the screen as attached
After searching "Text" select "Make text and other items larger or smaller". In "Change only the text size" click for the drop down and select "Icons".
The long way is at Settings/Display/Advanced display settings/Advanced sizing of text and other items/Change only the text size/Icons.
Simply checking "Bold" may be all you need.
You can search "text" directly from the task bar.
