My suggestion would be to perform an in-place upgrade repair. That is to say...... upgrade it again, overtop of itself from within your current install, just double click setup.exe in the installation media. Just be sure to check the little box to get updates as part of the upgrade process.
That will generally keep all your programs, data, drivers and such safe, but.....
I would still create a disk image before going forward.
Installation media can be obtained here
If you already have the ISO you can simply mount it from within Windows 10 and run setup.exe from there.
Neosmart has a pretty good article on it here
https://neosmart.net/wiki/windows-10-repair-installation/
You can skip the first couple paragraphs where they are promoting their recovery CDs and drill down to the meat of the article below.
