Try going to Powershell and run this command to reset Edge. You can get to PowerShell by right-clicking on the Windows icon in the bottom left and click on Command Prompt (Admin). Once Command Prompt comes up, type Powershell.
i found info that programmes like keyscrambler cause the search bar problem. disabling/uninstalling was recommended. i haven't tried the solution, i will just switch back to chrome or mozzila instead. hate edge anyway. pls let me know if you tried and it worked
