SOLVED Edge keeps refreshing pages
This is really annoying, especially when I get part-way through filling a form on a web page and then lose everything and have to start again. Racing to fill in this post!
Hi Andy,
have you tried running the latest updates?, what version of Windows 10 do you have?. Press the Windows key + r and type winver. :):):)
Thanks for your reply Wolfie.
The version number is 1809 build 17763.134.
I discovered this 'repair' option (settings>edge>advanced options)
so I'm trying that now. If it doesn't work then I'll try the 'reset' option.
I'll get back to you if and when I'm confident that it has or hasn't fixed it.
The 'repair' option didn't work, but it hasn't happened again since I deployed the 'reset' option.
Looks like it fixed. Thanks for taking an interest Wolfie.
