Edge doesn't appear in taskbar.
Even though it's running. This means that when I have it maximized and then click minimize, there's no way for me to maximize it again. What do I do? Thanks in advance for your assistance.
Can you go to Start>right click Edge>More>Pin to Taskbar?
Sorry for taking so long to reply back. That's not what I meant, yodap. You know how when you have a program running it appears on the taskbar? Well, that doesn't happpen when I run Microsoft Edge on my computer.
Ah I see, I'm not using Edge much but I just opened it and it's there on the task bar when opened and still there when minimized and gone when it's closed. Hopefully some one will come along with the right answer.
Meanwhile you can try method 2 or 3 here
