Edge browser doesnot remember the window position
HCV
I use two displays and Windows 10 works almost perfect. The problem is, that Edge remenbers the size of the window, but not the position. Edge opens always on the first display. If i use explorer 11 it opens on the same location as befor. The pathfinder also always remenber the exact location with windows 10. My guestion is how to force Edge to open on the second display.
Ian
Administrator
Yes, I have the same issue too. It may be worth submitting MS a bug report / suggestion about this and see if they can incorporate it.
The only way I can see to workaround this issue is to use a 3rd party app as follows:
http://www.desksoft.com/WindowManager.htm
I primarily use IE11 on my dual monitor setup and edge on my tablet, so it doesn't affect me too much, but I can imagine it's a pain for other users.
