I have been experiencing this issue intermittently for a long time. Sometimes it will happen several times in a day and then not happen for a week or more.
WhoCrashed finds no offending drivers and so I am at a loss.
System Information (local)
Computer name: XXXXXXXX
Windows version: Windows 10 , 10.0, build: 17134
Windows dir: C:\Windows
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., X99-DELUXE
CPU: GenuineIntel Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz Intel586, level: 6
12 logical processors, active mask: 4095
RAM: 34267729920 bytes (31.9GB)
On Tue 1/8/2019 12:55:27 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010819-18500-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1AA0A0)
Bugcheck code: 0x9F (0x3, 0xFFFFBE01DCBA3E20, 0xFFFF9208AD0538D0, 0xFFFFBE01E59E7AB0)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. A device object has been blocking an IRP for too long a time.
This is likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
