- Jul 29, 2016
Greetings: I formatted my HD and did a clean installation using a Win10 DVD that I made using the MS Media Creation Tool. When I finished loading the OS, I checked Device Manager, and all of the drivers appeared to be loaded (well, except for my scanner's SCSI card drivers).
NIC card drivers, USB 3 chipsets, Intel Chipsets, etc., all seemed to be there and are working, even though that was 'never' true under Win7. Under Win7, I always had to run a Driver disk following a clean install of the OS to load all of those drivers.
My principle concern is with the Intel chipsets. How can I be sure that they are properly installed? If I don't have any warning signs in Device Manager, does that mean I'm good to go?
Thank you for your help!
Kindest Regards,
David
Dell OptiPlex 980
Windows 10 Pro
Intel i7 Processor
512 GB Samsung SSD
16 GB RAM
Asus 24" ProArt Monitor
Kindest Regards,
David
Dell OptiPlex 980
Windows 10 Pro
Intel i7 Processor
512 GB Samsung SSD
16 GB RAM
