Hi, any help gratefully received.
Brand new PC, connects to wifi for some minutes but then yellow error appears on wifi signal and connection is dropped.
PC Specs:
OS: Windows 10 Pro
Version: 10.0.17134 Build 17134
System type:x64 based PC
System SKU: Default string
Processor: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, 3192 Mhz, 6 Core(s), 12 Logical Processor(s)
Installed Ram: 16GB
100% not a problem with the network itself as other devices working fine.
The windows troubleshooter fixes this by resetting the wifi adapter and shows that the issue is related to the default gateway.
However, the fix is always temporary, i.e. a couple of minutes.
Following instructions online I have already:
- Restarted router and pc several times
- Changed channel and frequency on router
- Changed power management of network adapter
- Turned off antivirus
- Checked for Windows upate
- Checked for driver update for network adapter
- Manually setting IP and DNS
- reset ip, flush dns etc.
- Full network reset
The last time it dropped out it generated the following diagnostic information. I'm getting very frustrated... please help!
Details about network adapter diagnosis:
Network adapter Wi-Fi driver information:
Description . . . . . . . . . . : Realtek RTL8192CE Wireless LAN 802.11n PCI-E NIC
Manufacturer . . . . . . . . . : Realtek Semiconductor Corp.
Provider . . . . . . . . . . . : Microsoft
Version . . . . . . . . . . . : 2013.12.331.2016
Inf File Name . . . . . . . . . : C:\WINDOWS\INF\netrtwlane_13.inf
Inf File Date . . . . . . . . . : 11 April 2018 23:33:45
Section Name . . . . . . . . . : RTL8192Ce.ndi
Hardware ID . . . . . . . . . . : pci\ven_10ec&dev_8178&subsys_817810ec
Instance Status Flags . . . . . : 0x180200a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9
Details about wireless connectivity diagnosis:
Information for connection being diagnosed
Interface GUID: 1f162b9d-d5d4-4dc2-be60-56a0e09b74dd
Interface name: Realtek RTL8192CE Wireless LAN 802.11n PCI-E NIC
Interface type: Native Wi-Fi
Connection incident diagnosed
Auto Configuration ID: 1
Connection ID: 1
Connection status summary
Connection started at: 2018-08-12 12:00:36-538
Profile match: Success
Pre-Association: Success
Security and Authentication: Success
List of visible access point(s): 17 item(s) total, 17 item(s) displayed
BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
38-43-7D-C7-62-06 Infra <unknown> -58 7 Peej_home
2A-43-7D-C7-62-06 Infra <unknown> -58 7 Vodafone Homespot
26-43-7D-C7-62-06 Infra <unknown> -59 7 Vodafone Hotspot
00-24-FE-07-E3-80 Infra <unknown> -62 8 Wehlahn-Hansen
AC-22-05-8A-98-7A Infra <unknown> -61 6 WLAN-Leipzig
A6-22-05-8A-98-7A Infra <unknown> -63 6 Vodafone Hotspot
AA-22-05-8A-98-7A Infra <unknown> -68 6 Vodafone Homespot
84-94-8C-B8-D8-28 Infra <unknown> -67 6 HITRON-D820
46-67-51-7D-4C-2E Infra <unknown> -73 11 Vodafone Hotspot
54-67-51-7D-4C-2E Infra <unknown> -72 11 Cybernet Interspace
4A-67-51-7D-4C-2E Infra <unknown> -75 11 Vodafone Homespot
FA-8F-CA-6C-08-69 Infra <unknown> -76 6 (Unnamed Network)
9C-5C-8E-C7-C6-10 Infra <unknown> -71 13 Dr3iRaD
E0-28-6D-38-7D-97 Infra <unknown> -73 1 thenewnetwork
54-67-51-C4-B3-07 Infra <unknown> -76 11 KabelBox-A3D4
46-67-51-C4-B3-07 Infra <unknown> -76 11 Vodafone Hotspot
F4-F2-6D-EA-C8-4C Infra <unknown> -70 1 KDG-1E9FD
Connection History
Information for Auto Configuration ID 1
List of visible networks: 12 item(s) total, 12 item(s) displayed
BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra <unknown> Yes 79 Yes Peej_home
Infra <unknown> No 79 Yes Vodafone Homespot
Infra <unknown> No 76 Yes Vodafone Hotspot
Infra <unknown> Yes 74 Yes Wehlahn-Hansen
Infra <unknown> Yes 70 Yes WLAN-Leipzig
Infra <unknown> Yes 62 Yes HITRON-D820
Infra <unknown> Yes 62 Yes Cybernet Interspace
Infra <unknown> No 58 Yes (Unnamed Network)
Infra <unknown> Yes 58 Yes Dr3iRaD
Infra <unknown> Yes 58 Yes thenewnetwork
Infra <unknown> Yes 58 Yes KabelBox-A3D4
Infra <unknown> Yes 56 Yes KDG-1E9FD
List of preferred networks: 1 item(s)
Profile: Peej_home
SSID: Peej_home
SSID length: 9
Connection mode: Infra
Security: Yes
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: Yes
Information for Connection ID 1
Profile: Peej_home
SSID: Peej_home
SSID length: 9
Security: Yes
Pre-Association and Association
Connectivity settings provided by hardware manufacturer (IHV): No
Security settings provided by hardware manufacturer (IHV): No
Profile matches network requirements: Success
Pre-association status: Success
Association status: Success
Last AP: 38-43-7d-c7-62-06
Configured security type: WPA2-PSK
Configured encryption type: CCMP(AES)
802.1X protocol: No
Key exchange initiated: Yes
Unicast key received: Yes
Multicast key received: Yes
Number of security packets received: 0
Number of security packets sent: 0
Security attempt status: Success
Connectivity
Packet statistics
Ndis Rx: 1119
Ndis Tx: 1032
Unicast decrypt success: 61
Multicast decrypt success: 0
Unicast decrypt failure: 0
Multicast decrypt failure: 0
Rx success: 494
Rx failure: 0
Tx success: 53
Tx failure: 0
Tx retry: 0
Tx multiple retry: 0
Tx max lifetime exceeded: 0
Tx ACK failure: 0
Roaming history: 0 item(s)
For complete information about this session see the wireless connectivity information event.
Helper Class: Auto Configuration
Initialize status: Success
Result of diagnosis: There may be problem
Details about wireless network adapter diagnosis:
Helper Class: Native Wi-Fi MSM
Profile: Peej_home
SSID: Peej_home
SSID length: 9
Security: Yes
PC Specs:
OS: Windows 10 Pro
Installed Ram: 16GB
Connection ID: 1
Connection History
Profile: Peej_home
SSID: Peej_home
SSID length: 9
Security: Yes
Connectable: Yes
Profile: Peej_home
SSID: Peej_home
SSID length: 9
Security: Yes
802.1X protocol: No
Connectivity
Packet statistics
Ndis Rx: 1119
Ndis Tx: 1032
Rx success: 494
Rx failure: 0
Tx success: 53
Tx failure: 0
Tx retry: 0
Tx ACK failure: 0
Profile: Peej_home
SSID: Peej_home
SSID length: 9
Security: Yes
