SOLVED Custom drive icons with not related to letters...
Hi all.
For those who are interested, I have gathered some of the codes corresponding to the basic drive icons of the discs that I use.
If you have other codes (functional with Windows 10) I take!
In down, the corresponding registery data (make with notepad or other and change the .txt to .reg) and double-click... If your custom icons are not in the C:\Windows\MyIcons folder, otherwise, modify the file accordingly.
It's up to you to make your custom icons or to download them on the internet (hard to find all of them).
Bye
Jean-Claude
__
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell MyIcons]
"6"="C:\\Windows\\MyIcons\\Floppy.ico"
"7"="C:\\Windows\\MyIcons\\HD_USB.ico"
"8"="C:\\Windows\\MyIcons\\HD_Std.ico"
"9"="C:\\Windows\\MyIcons\\HD_Red.ico"
"10"="C:\\Windows\\MyIcons\\HD_Red_Out.ico"
"11"="C:\\Windows\\MyIcons\\CD.ico"
"59"="C:\\Windows\\MyIcons\\DVD.ico"
"107"="C:\\Windows\\MyIcons\\HD_Windows.ico"
"164"="C:\\Windows\\MyIcons\\HD_Bitlocker_.ico"
"165"="C:\\Windows\\MyIcons\\HD_Bitlocker_Out.ico"
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\Shell MyIcons]
